Hi: I'm using a scatter file in the project options (linker tab) in order to have part of the code running on a different memory region. As an example;
IRAM 0x30000000 { ; The executable region starts at the load region ER_RO 0x30000000 { startup_code.o (STARTUP, +FIRST) * (+RO, +RW) } ER_ZI +0 { * (+ZI) } ER_OTHER 0x30001000 { function2.o (+RO, +RW, +ZI) } }
The problem is that even when the memory map shows function2 is allocated at the right memory position (0x30001000), when I try to debug the code, the correct assembly code is not there...So, why the code is not copied into this position if the memory map is correct? Thanks; Gus
Given that the name of your region is IRAM, I'm assuming you are trying to debug out of RAM and not Flash? If so do you have a debug script to load the program into ram when you start the debugger?
Something like:
LOAD your.axf PC = 0x30000000
