bitfields in bdata behaviour
If a bdata variable is defined in the form:
struct foo
   unsigned char b1:1;
   unsigned char b2:1;
   unsigned char b3:1;
   unsigned char b4:1;
   unsigned char b5:1;
   unsigned char b6:1;
   unsigned char b7:1;
   unsigned char b8:1;
} bdata myflags;
Will the code:
if (myflags.b3)
   // do something
or the code:
myflags.b5 = 1;
generate the efficient 8051 code using jb, setb, etc?
I will do some testing myself, but in the meantime I'd like to know your ideas and advices.
I am porting some C code to Keil C51 and I am wondering if I can avoid the use of the bit and sbit keywords which are heavy extensions to C.
Thanks,
Nestor
