is it allowed to have a USB composite device with 2 MSC interfaces?
Is this supported? from the usbcfg.h file, it seems that this is not supported as one can only indicate the number of one MSC interface. what I want is simple: a device that will map itself to two distinct windows drives. is that allow/supported?
  • this is dangerous to have of course in terms of file system access rights (is that the reason I don't get it to work?)
  • You may have two (or more) MSC interfaces on single device.
    But it means you have to duplicate everything on the source code for the multiple MSC interfaces - descriptors, request and endpoint handlers.
    Instead, you may declare two (or more) logical units (drives) under single MSC interfaces - just like attaching two hard disks under ATA.
    For two drives, return 1 for Get_Max_Lun request.
    And then, the host specifies the LUN (Logical Unit Number) for CBW and SCSI commands, to access one of the drives.
    Tsuneo
