C51 v8.17 saving/restoring all registers in interrupt function with assembly src
C51 will generate different code for the following function:
void timer1 (void) interrupt 3 {
    second;
#pragma asm
    clr    TF1
#pragma endasm
Compiler v8.08 code (edited)
    USING    0
timer1:
; #pragma asm
    clr    TF1
; #pragma endasm
    RETI
Compiler v8.17 code (edited)
    USING    0
timer1:
    PUSH     ACC
    PUSH     B
    PUSH     DPH
    PUSH     DPL
    PUSH     PSW
    MOV      PSW,#00H
    PUSH     AR0
    PUSH     AR7
    USING    0
; #pragma asm
      clr    TF1
; #pragma endasm
    POP      AR7
    POP      AR0
    POP      PSW
    POP      DPL
    POP      DPH
    POP      B
    POP      ACC
    RETI
C51 v8.17 generates code to save and restore all registers, as soon as the (very simplified, nonsense) C function contains any assembly source, whereas C51 v8.08 does not. For a function containing equivalent C code only (TF=0), nothing would be saved with either version.
Is there a reason for the different code generated by v8.17 ? How could saving/restoring of the registes be avoided ?
  • self proclaimed villain,
    I'm sure most of the sensible comments on this forum escape your wit. but don't worry, it will come, in time.
    p.s.
    are you a trekkie?
  • that the '51 architecture is not fully capable of peocessing all C constructs in an effective manner evidently, in the opinion of a certain sardine, makes the processor the villian.
    Erik (NOT hiding behind a monmniker)
    Again you completely, and probably deliberately, miss the point.
    The point is that a professional engineer should read the manual - a point you yourself make with tiresome regularity. Reading the manual in the context of the programming language that you (yes, *you*) use means reading the 'C' standard or some alternative reference that describes the 'C' language as defined by the 'C' standard, such as H&S (Harbison and Steele).
    Now, you'll argue that you don't use standard 'C' but in fact use Keil 'C' therefore the 'C' standard is irrelevant to you and your reference is the Keil documentation. This argument is false - Keil's job is to document what their implementation adds to standard 'C', not to document the standard 'C' part of their implementation which forms the majority of the source code you type into your text editor.
    The sooner you manage to understand this the sooner you will hopefully do something about it. Once you've done something about it you'll find that you spend far less time debugging and far more time producing working code.
    Your repeated implication that learning the 'C' programming language properly somehow makes one unable to write code that is suitable for use on an 8051 derivative is frankly laughable, the reality is that *not* learning the language renders one unfit to write code for *any* architecture.
  • Now, you'll argue that you don't use standard 'C' but in fact use Keil 'C'
    IN CONTEXT:
    1) NOT Keil C" but "'51 C"
    2) 'standard C has many 'features' that the '51 is inacabable of processing efficiently and such constructs should thus be avoided.
    If you did not know C you would be at a loss using Keil C. I do not discuss 'learning' or 'knowing' but 'applying'
    I have never stated "that learning the 'C' programming language properly somehow makes one unable to write code", what I have stated and will restate is that "if you approach '51 programming with the attitude "I am using C so I do not need to be concerned with the archiotecture" your ability to make efficient code is not even that of a sardine
  • IN CONTEXT:
    There is standard 'C' of which there are implementations, many of which include extensions to the standard. '51 C' is merely a figment of your imagination.
    In your opinion, perhaps. Efficiency (by which I assume you mean speed and/or code size) is only relevant if it matters, otherwise clarity and maintainability should take precedence.
    As you're so very fond of them, here's a car analogy:
    You need to drive somewhere 100 miles away. You need to be there in 6 hours. Do you:
    1) Drive at a sensible speed and get there in plenty of time.
    2) Drive flat out and get there way too early.
    You cannot 'apply' without first 'learning' and hopefully 'knowing'. I can only judge your state of knowledge by what you post on this forum, and I'm afraid your code snippets and queries along with your comments on the 'C' language betray a worrying lack of it.
    Ah yes, the old 'Malund trick', snipping the important bit of the quote:
    Which is, in fact, what you repeatedly imply. Don't you even have your own little nickname for people who know 'C' well?
    Er, fascinating, but not what is being discussed. That's 'Malund trick 2', number three, if I recall, will be answering the question you would prefer to have been asked rather than the one you have been asked.
  • Woohoo.
    Go Jack, go Jack, gooooooooooooo Jack!
  • Which is, in fact, what you repeatedly imply. Don't you even have your own little nickname for people who know 'C' well?
    Not that I know of, I would call them knowledgeable.
    HOWEVER "if you approach '51 programming with the attitude "I am using C so I do not need to be concerned with the archiotecture" I call you a Cidiot
    Well, that's a breakthrough. I'd have thought you'd aspire to be one of them, but there you go.
