Hi there, I am trying to config LPC930's uart port using the following codes: void uart_init ( void ) { // configure UART // clear SMOD0 PCON &= ~0x40; SCON = 0x50; // set or clear SMOD1 PCON &= 0x7f; PCON |= (0 << 8); SSTAT = 0x00;
// configure baud rate generator BRGCON = 0x00; BRGR0 = 0xF0; BRGR1 = 0x02; BRGCON = 0x03;
// TxD = push-pull, RxD = input P1M1 &= ~0x01; P1M2 |= 0x01; P1M1 |= 0x02; P1M2 &= ~0x02;
// initially not busy mtxbusy = 0;
// TI = 0; // set isr priority to 0 IP0 &= 0xEF; IP0H &= 0xEF; // enable uart interrupt ES = 1;
} // uart_init
and after calling this uart_init() i then tried to do a printf("hello world\n");
actually i did the printf() in a while(1) loop, hoping to catch something on the PC terminal. however, i dont get anything. then i tried to probe the TxD pin on LPC930, then i saw only one pulse going from high to low at the time the printf() should be executed. Can anyone help me with this issue?
I am using LPC930, internal xtal @ 7.373MHz, desired baudrate is 9600.
thanks
looks like the code is messed up. this is the cleaner one:
// clear SMOD0
PCON &= ~0x40;
SCON = 0x50;
PCON &= 0x7f;
PCON |= (0 << 8);
SSTAT = 0x00;
BRGCON = 0x00;
BRGR0 = 0xF0;
BRGR1 = 0x02;
BRGCON = 0x03;
P1M1 &= ~0x01;
P1M2 |= 0x01;
P1M1 |= 0x02;
P1M2 &= ~0x02;
mtxbusy = 0;
IP0 &= 0xEF;
IP0H &= 0xEF;
ES = 1;
I think it's your eyes that must be messed up - the instructions look pretty clear to me:
www.danlhenry.com/.../keil_code.png
i now see why sometimes people think another individual is a jerk...this He Li guy messed up the code and then jumps out a guy saying this He Li's eyes are messed up...very friendly, indeed.
Andy is normally one of the most civil contributers to this forum, sir. Calling someones a jerk is not that friendly, either...!
Andy is the saint.
I'm the ruffian
(but I normally end up wanting, when Erik is at his best) :)
OK, so he did at least notice that the code was "messed up" - which is more than can be said for many!
But, the thing is: attention to detail is absolutely fundamental to programming - especially embedded programming.
I content that the instructions for posting source code are very clearly stated before your very eyes whenever you make a post to this forum - as highlighed in the picture:
If anyone can miss something stated that clearly, it must suggest a very high likelihood that they will also miss important details in the datasheets, etc - details which would be essential to getting stuff to work!
Have you tried the "Hello, world" sample provided by Keil?
Does that work?
