Hi
I am trying to multiplex 4 RXD (RS232 level) signals from 4 different devices using IC C4066 to 8051 via MAX232.
Ch.1 --------
Ch 2 -------- IC 4066 ----- MAX 232 ---- 8051
Ch 3 --------
Ch 4 ---------
All 4 outputs of CD4066 are shorted.
Only ONE Channel is ENABLED at a TIME.
However, it appears that there is some channel crosstalk that is probably causing some problem.
Can anyone suggest how to eliminate this ?
Sulax
Have you looked in the FAQ section of the C51 programmers guide?
Probably a situation caused by misunderstanding of operator precedence.
What voltage do you feed the 4066 with? Are you sure it supports voltages above VCC or below zero?
Where exactly I have look for this FAQ ?
Can u forward me the link of this webpage.
Rgds Sulax
