HI ALL.
WHAT I MUST DO IS WRITE AN ALGORHYMN TO REMOVE THE DC OFFSET FROM A SIGNAL? (15-20V DC (NOT CONSTANT AND WILL NORMALLY BE IN THIS RANGE), 1 VPP SIGNAL OVERLAID ON TOP OF IT) I AM TRYING TO GET THE 1VPP OUT OF IT.
REGARDS, BORBEK.
YOUR CAPS LOCK KEY APPEARS TO BE STUCK - PLEASE FIX IT.
POSTS IN ALL CAPITALS ARE HARD TO READ!
WRITING IN ALL CAPITALS IS OFTEN CONSIDERED TO BE SHOUTING - AND, THEREFORE, RUDE - so please don't do it!
sorry. i am new to keil forum.
Why did you think that writing in ALL CAPITALS would be a good idea on any forum?
Why, in fact, would you ever specifically choose to write in ALL CAPITALS?
I would be genuinely interested to know - as it's surprising how many people do it!
it looks cool.
Do you really think so??!
Anyhow, back to your algorithm, what thoughts have you had so far?
Have you googled?
What might be a good way to identify a steady offset on a varying signal...?
Note that this has nothing specifically to do with Keil or ARM.
Have you checked the Datasheet for your chip to see if it has any useful features that might be of use?
