Hello!!
I have problem witch initiation USART in STM32 microcontroler. I use standard KEIL configuration file to setup USART. After configuration (I stop program witch while(1) function) but I receive in Windows Terminal one unexpected sign. I can't eliminate this problem...
What file is that, then?
" I receive in Windows Terminal one unexpected sign"
What sign did you receive?
What sign did you expect?
What debugging work have you done in an attempt to account for the difference?
See my post of 13-Apr-2009 12:48 about about Debugging in this thread: http://www.keil.com/forum/docs/thread14627.asp
I use STM32_Init.c file for configuration. It is standard configuration file from Keil MDK.
My aplication is very simple:
int main(void){
stm32_Init(); /* In this file I make usart configuration */
while (1); }
After execute firs line of the code, I receive this sign "ü".
Hello Mark Anders,
I can not explain what causes this extra character during UART initialisation but you can eleminate it if you add a little for-next loop before enabling the UART.
for (i = 0; i < 800; i++); USART1->CR1 |= USART_CR1_UE;
Best Regards, Martin Guenther
It is not at all unusual for any system to generate the odd "glitch" on startups - with a serial connection, that may well show up as an odd character...
