i want to know hw can i intialize the variables placed at specific memory location using the _at keyword. The memory region is NOINIT enabled.. whenever i try to intialize these varibles i got the error error:expected a ; i m using the keil microvision3 with RV compiler... plzzz help..if anybody hv any solution or any idea..
thanx........
www.keil.com/.../armccref_babgjhdc.htm
thanx 4 the link..its really useful..... bt the prblm is that the variables that i want to intialize are in NOINIT area.. so whenever i intialize them i got the linker error..is there any way possible to intialize NOINIT area variables....as i cant chng the NOINIT option....????
That makes no sense whatsoever. You're directly contradicting yourself in the space of a single sentence.
You might as well want to make a quadrangle without any corners.
Can't you simply initialise at the start of main?
i think there is no harm in asking smthing to confirm it..or to take opinion from anyone else..iff u got stuck smwhere.. u may be knowing more but at least sm decency can be maintained while posting replies....
