Hello I am completely new to this ARM board development. But is it possible to use Keil to develop the STR-E912 board from Olimex? I have a JTAG Tiny from Olimex and have installed the driver and everything but i do not know how to set it up to Keil uVersion 3. Do I use the Ulink ARM Debugger or the Jlink/Jtrace? Thank you very much.
As far as I know, the current version does not support JTAG Tiny. I may be wrong, though - did you try to contact the technical support?
You mean the special support for Olimex or Keil? For Olimex i only have the number from there webpage. If Keil is not compatible with Tiny then what IDE should i use?
