Problem with os_dly_wait() and ULINK
Using ARTX Version 2.02 in our project we have the following problem:
We use the os_dly_wait()-function in two different tasks. Running our ULINK to debug the code and stepping through the source code we frequently get the following messages after the execution of this function:
Memory access not possible. CPU is in Idle, Sleep or Power-Down mode.
and
JTAG Communication Failure
I reduced the source code to the following lines:
void Task1 (void) _task_ TASK_1 {
unsigned long ulTest = 0;
        while(1){
                os_dly_wait (40);
                ulTest++;
and
void Task2 (void) _task_ TASK_2 {
        while(1){
                os_dly_wait (40);
                ulTest++;
the communication to the ULINK was interrupted, but the application on out target system is still running.
What can be the reason for this ??
