Adding a 2nd party xxx.lib file to my uV3 (V3.30) project causes ERROR L218 NOT AN OBJECT FILE. xxx.lib was created on uV3 (V3.90), any ideas? Even when right-click on the .lib file, uV3 reports "Not a library file".
In the "properties/file type" area for this file it is designated as a Library file. Anything else I should look for, thanks.
Not uncommon to get problems when linking a library built with a different version of the tools - especially if using c++.
Does it make a difference if you try to build a little library with your version of the compiler?
Have you asked Keil support?
That simply tells the tools to assume that anything with a .lib extension is to be treated as a Library file - it is up to you to ensure that your .lib file is valid for use with your particular version of the Keil tools.
Have you done that?
Thanks all, solved. The library was built using RealView and I was using CARM. I've made the switch to RealView and all is well.
