MCB2100 problems with reset
Hello everybody
I don't know if this is only mine problem but I have problem with MCB2100 starter kit. Problem is that reset button don't work correctly. After power reset, reset work correctly but using reset button works only few times and later doesn't work and all leds stays on.
Also it isn't resseting with Keil ULINK and ULINK2. So after uploading flash it doesn't reset board and is not possible to debug.
I added additional capacitors (10uf) to all voltage regulators and works better but after some time the problem come back. Also I checked all reset circuit, replace components and even mcu but still the same.
Any suggestions what can be problem??
Regards
