nested Interrupts
Hello all,
i use the RealView Compiler but by Compiling the lower C-Code the Compiler reports:
error: #20: identifier "LR" is undefined
error: #20: identifier "SP" is undefined
Thank you for your help
/*This file is create using Keil uVision/ARM and the /*Keil CA ARM Compiler */
/*Copyright KEIL ELEKTRONIK GmbH 2004
#include <LPC21xx.H> /* LPC21xx definitions */
int volatile intrp_count = 0;
int volatile timeval = 0;
int volatile SecondCnt = 0;
// Macros for Interrupt Nesting
#define IENABLE /* Nested Interrupts Entry */
__asm { MRS LR, SPSR } \
__asm { STMFD SP!, {LR} } \
__asm { MSR CPSR_c, #0x1F } \
#define IDISABLE /* Nested Interrupts Exit */ \
__asm { LDMFD SP!, {LR} } /* RestorLR */ \
__asm { MSR CPSR_c, #0x92 } \
__asm { LDMFD SP!, {LR} } \
__asm { MSR SPSR_cxsf, LR } \
/* Timer Counter 0 Interrupt executes each 10ms @ 60 MHz CPU Clock */
void tc0 (void) __irq {
++timeval;
if ((timeval % 10000) == 0) {
timeval = 0;
SecondCnt++;
T0IR = 1; // Clear interrupt flag
VICVectAddr = 0; // Acknowledge Interrupt
/* Setup the Timer Counter 0 Interrupt */
void init_timer (void) {
T0MR0 = 1499; // 0.1mSec = 1.500-1 counts
T0MCR = 3; // Interrupt and Reset on MR0
T0TCR = 1; // Timer0 Enable
VICVectAddr0 = (unsigned long)tc0;
VICVectCntl0 = 0x20 | 4;
VICIntEnable = 0x00000010; // Enable Timer0 Interrupt
/* Create a long time delay */
void delay (void) {
int i;
for (i = 0; i < 0x50000; i++) {
/* External Interrupt 1 Service */
void eint1_srv (void) __irq {
int i;
EXTINT = 2; // Clear EINT1 interrupt flag
IENABLE; // allow nested interrupts
delay (); // wait a long time
++intrp_count; // increment interrupt count
IDISABLE; // disable interrupt nesting
/* Initialize EINT1 Interrupt Pin */
void init_eint1 (void) {
EXTMODE = 2;// Edge sensitive modeonEINT1
EXTPOLAR = 2;// raising edge sensitive
PINSEL0 = 2 << 28;// Enable EINT1 on
VICVectAddr1 = (unsigned long) eint1_srv;
VICVectCntl1 = 0x21 | 15;
VICIntEnable = 1 << 15;// Enable EINT1 Interrupt
int main (void) {
unsigned int LED_out = 0;
IODIR1 = 0xFF0000;
init_eint1(); // Enable EINT1
init_timer ();
while (1) {
if ((intrp_count & 0xFF) != LED_out) { // intrp_count has changed
LED_out = (intrp_count & 0x7F);
IOCLR1 = 0x7F0000;
IOSET1 = (LED_out << 16);
if ((SecondCnt & 1) == 0) IOCLR1 = 0x800000;
else IOSET1 = 0x800000;
} Thanks
