Retarget.c
My app is with stm32.
But I think it's the same problem.
Use the right Retarget.c file will do.
You can download form Keil
"http://www.keil.com/download/docs/369.asp"
"RL-ARM SD/MMC File Demo for MCB2400"
It's like this:
/*---------------------------------------------------------------------------- * R T L - F l a s h F i l e S y s t e m *---------------------------------------------------------------------------- * Name: RETARGET.C * Purpose: Retarget low level functions * Rev.: V3.20 *---------------------------------------------------------------------------- * This code is part of the RealView Run-Time Library. * Copyright (c) 2004-2008 KEIL - An ARM Company. All rights reserved. *---------------------------------------------------------------------------*/
#include <stdio.h>
#include <string.h>
#include <rt_misc.h>
#include <rt_sys.h>
#include <File_Config.h>
#pragma import(__use_no_semihosting_swi)
/* The following macro definitions may be used to translate this file:
STDIO - use standard Input/Output device (default is NOT used) */
/* Standard IO device handles. */
#define STDIN 0x8001
#define STDOUT 0x8002
#define STDERR 0x8003
/* Standard IO device name defines. */
const char __stdin_name[] = "STDIN";
const char __stdout_name[] = "STDOUT";
const char __stderr_name[] = "STDERR";
struct __FILE { int handle; /* Add whatever you need here */ };
#ifdef STDIO extern int sendchar (int ch); extern int getkey (void);
#endif
/*--------------------------- _ttywrch --------------------------------------*/
void _ttywrch (int ch) {
#ifdef STDIO sendchar(ch);
#endif
/*--------------------------- _sys_open -------------------------------------*/
FILEHANDLE _sys_open (const char *name, int openmode) { /* Register standard Input Output devices. */ if (strcmp(name, "STDIN") == 0) { return (STDIN); } if (strcmp(name, "STDOUT") == 0) { return (STDOUT); } if (strcmp(name, "STDERR") == 0) { return (STDERR); } return (__fopen (name, openmode));
/*--------------------------- _sys_close ------------------------------------*/
int _sys_close (FILEHANDLE fh) { if (fh > 0x8000) { return (0); } return (__fclose (fh));
/*--------------------------- _sys_write ------------------------------------*/
int _sys_write (FILEHANDLE fh, const U8 *buf, U32 len, int mode) {
#ifdef STDIO if (fh == STDOUT) { /* Standard Output device. */ for ( ; len; len--) { sendchar (*buf++); } return (0); }
#endif if (fh > 0x8000) { return (-1); } return (__write (fh, buf, len));
/*--------------------------- _sys_read -------------------------------------*/
int _sys_read (FILEHANDLE fh, U8 *buf, U32 len, int mode) {
#ifdef STDIO if (fh == STDIN) { /* Standard Input device. */ for ( ; len; len--) { *buf++ = getkey (); } return (0); }
#endif if (fh > 0x8000) { return (-1); } return (__read (fh, buf, len));
/*--------------------------- _sys_istty ------------------------------------*/
int _sys_istty (FILEHANDLE fh) { if (fh > 0x8000) { return (1); } return (0);
/*--------------------------- _sys_seek -------------------------------------*/
int _sys_seek (FILEHANDLE fh, long pos) { if (fh > 0x8000) { return (-1); } return (__setfpos (fh, pos));
/*--------------------------- _sys_ensure -----------------------------------*/
int _sys_ensure (FILEHANDLE fh) { if (fh > 0x8000) { return (-1); } return (__flushbuf (fh));
/*--------------------------- _sys_flen -------------------------------------*/
long _sys_flen (FILEHANDLE fh) { if (fh > 0x8000) { return (0); } return (__get_flen (fh));
/*--------------------------- _sys_tmpnam -----------------------------------*/
int _sys_tmpnam (char *name, int sig, unsigned maxlen) { return (1);
/*--------------------------- _sys_command_string ---------------------------*/
char *_sys_command_string (char *cmd, int len) { return (cmd);
/*--------------------------- _sys_exit -------------------------------------*/
void _sys_exit (int return_code) { /* Endless loop. */ while (1);
/*---------------------------------------------------------------------------- * end of file *---------------------------------------------------------------------------*/
