Dear Sir madams,
we wish use linklist to effishiently sort data then build tree in are controllar.
In your humble oppionion,it is wong use malloc,calloc and realloc in 8051?
Can you advise? It first year in industry after study in Beijing.
Worry I make mistak
Xin Nian Kuai Le
I use it all the time, just go ahead. Good luck with you career.
but you can easily write an implementation of a linked list that does not use dynamically allocated memory. are you sure that you are using the right data structure? for faster operations, you can use a hash table, for example.
Thanking you btoh but me more comfused hear. malloc is needad becaurse of variable input data. We never know size of input.I think we use malloc to dynamikally alocatte space like Justin says yes? No fixed size at factory.
using dynamically allocated memory comes with a cost - memory fragmentation which slows memory access over time is one of them. if a path in the program fails to release it, you are in serious trouble. don't forget that you are not working on a powerful PC. better to allocate a large buffer statically and limit the maximum amount of incoming data, or ignore it is it exceeds maximum allowed size. but if you choose to use it anyway, don't forget to check the return value of the allocating function!
Thank you. Think i see what you say. unnowm size, unnowm memory leek. Bad for us. dangerus for hole viallage.We speak to boss to tell him limits.but need know which mefod is more effishient?
Malloc can be useful if you do not know the size that something needs to be at compile time, and you have two competing needs for memory.
If you have to free allocated memory then fragmentation becomes a problem.
As with lots of C code care is need.
Efficiency depends on what you are trying to do.
your problem is that you are trying to apply large processor techniques/applications to a small processor.
With a large fast processor, such as a PC you can code based on 'programmer efficiency' with a small slow processor (e.g. a 12MHZ 12 clocker '51) you have to code for 'processor efficiency'
wrong is a strong word. Will it work sure but it will be bigger and slower than other methods. You better know how much data you are getting embedded systems have to handle errors on there own. What will yours do if it has too much? Have you chosen the correct CPU?
But you do still need to know the maximum size at compile time - because you have to define the heap size!
So, given that you have to fix the heap size at build time anyhow, you might just as well define the data structures "statically".
As has already been mentioned, it is not necessary to use dynamic allocation in order to use linked lists!
It is perfectly fine to define a static set of list entries, and simply link them into an "in-use" list or a "free" list as & when required at runtime.
That gives you all the convenience of linked lists with none of the risks & overheads of dynamic allocation.
Of course, the 8051 is still not a great choice for a "data processing" task like this; an ARM would probably be a better choice - and may well be no more expensive...
