Hi All
I am using the MDK micro version 3.3 , now i downloaded the MDK-ARM4.0 and installed it, open my project in version 4.0 and compile it working fine but when i try to download the code using ulink2 i get any error stating "EEROR : Flash Download Failed-This old version of 'SARM.DLL' is incompatible with the version (UV3.EXE) Please use a consistent installation.
Plz advice on this i am not able to load using this .
Regards Suresh
uVision4 Beta 1 is not compatible with MDK-ARM 3.3 and other older uVision toolchains.
Please upgrade your toolchain to the latest version in order to try the uVision4 Beta.
To update, simply go to the 'Help->Check for Update...' option in uVision3, or visit:
http://www.keil.com/update/
If you have already installed uVision4, don't worry. Just install the toolchain upgrade in the same folder and then uVision4 should work.
Richard
Hi Richard
Thanks for the help will try this .
