I Have downloaded the ethernet code from code bundle.zip it is working properly but iam unable to trace the IP address of the board.So please any one help me to identify the IP address of the evaluation board of LPC2378
192.168.4.92
Remember that if the address is assigned through DHCP, it may differ for every single user that connects a board to their local network, depending on configuration of the DHCP server, and what other machines are requesting network addresses.
The board itself does not have an IP address; it is not an attribute of the hardware. It is assigned by the software - possibly dynamically (as Per said).
hi sir
Thanks for reply
sir,actually i have connected the LPC2378 Evaluation board to the SYSTEM.I have pinged with the following IP address
but reply from the board is not coming.so,sir reply is based on the IP address of the System?
so can you please give me the IP address which the system has to be set.
thanking you
Have you read this document: http://www.keil.com/mcb2300/mcb2300_quickstart.pdf
Do you have a DHCP server? If you have, then you should be able to check in the DHCP server what IP the board got.
If you haven't, then the document suggests how to set a fixed IP in the board.
There are also other methods to find a board, if you know the hardware addresss (MAC) of the board. Something for you to consider googling for.
Sounds like you need to spend some time to get up to speed with the basics of TCP/IP?
eg, see: compnetworking.about.com/.../TCPIP_Transmission_Control_Protocol_Internet_Protocol.htm
