Hi all,
I am working on making a switched mode arc welding machine with maximum 150A current and 30-40V. I have done most of the circuitry but the problem I face is the output current control. I do not want to use the bulky old linear type inductor, so what can be the solution?
I have seen in some SMPS welding machine (in schematics), current is controlled with a small ferrite core inductor. I tried to find out the calculation and procedure, but could not find out from any book or internet the required procedure for controlling output current through ferrite core inductor.
I require to control the output current to control the inrush current and also to use different type of welding rod with controlled current from 75A to 150A.
In some discussion on some forums, I found the idea of controlling output current through hall effect sensor. But nowhere it is discussed in detail. So, no concrete idea could have been formulated.
Help in this regard will be appreciated.
What does this have to do with Keil Software tools or products?!
A very interesting question. One that I never expected to see on this forum!
Linear Current control in SMPS is difficult, you can use a hall effect sensor from LEM. in lower current application up to 50 Amp I had used a Current sense resistor and an OP amp OP37 as the amplifier stage , with a low offset op amp the shunt dissipation can be kept low with the sense voltage in the range of 10 millivolt, this will be a lower cost approach than a Hall based design.
Instead of using a small shunt resistor, you could also consider using a hall-effect sensor. This sensor would have no drop in output voltage, but will be a bit more expensive to implement in the design.
That suggestion was already made by sigma erithal
I doubt the OP needs to be reminded after 11 years !!
