i am getting an error that doesnt make sense to me. im using a cypress cy7c68013a-128axc its either an fx2 or fx2LP. i was getting problems with address space overflows on the data, so i started to use
#define XBYTE ((unsigned char volatile xdata *) 0)
and now it gets me past the address overflow errors but still crashes on the hex2bix command.
Build target 'Target 1' compiling WPdev.c... linking... *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?C_INITSEG Program Size: data=64.6 xdata=4473 code=3260 creating hex file from "fw"... User command #1: HEX2BIX.EXE -i -f 0xc2 -v 0x185A -p 0x0040 -o fw.iic fw.hex --- Error: User Command terminated, Exit-Code = 1 "fw" - 1 Error(s), 1 Warning(s).
Have you checked if hex2bin can give a more descriptive error message if you run it manually from the command line?
Have you verified that all parameters to hex2bin are valid?
