MON51 require external ram or rom to work ? i m using the 89s8252 from atmel this microcontrol have 256 byte internal ram.
if i using this chip, 1. can i use the internal ram 256 byte for program code? without using the external ram ? 2. can i use the external ram, to store the program code and mon51 program ? 3. or MON51, must require external ram and rom, cant use interal ram ? external ram for store program code, and eeprom to store monitor51 program ?
You keep asking this question!
You are struggling because you have not studied the basics of the 8051!
"1. can i use the internal ram 256 byte for program code?"
No, you can not. Nobody can - it is an impossibility in the 8051 architecture!
Please take time to study the so-called "bible" for the 8051:
Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
And take a look at these Tutorials:
http://www.8052.com/tutorial
And get yourself a decent Book (or books):
http://www.keil.com/books/8051books.asp http://www.8052.com/links http://www.8052.com/book/
1. No you can Not. 2. Yes there is a trick to do this. But how are you going to get the Monitor in to RAM. 3.the 8052 has several memory spaces. some are read / Write, some are Read Only.
"some are read / Write, some are Read Only."
And only is is "execute".
(the clue is in the name...)
