I'm trying to call an assembly (.a51) function from a C file.
I had it working, but then now it refuses to work. I get an error
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_WAIT_MS?DELAY *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: __WAIT_MS MODULE: main.obj (MAIN) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: __WAIT_MS MODULE: main.obj (MAIN) ADDRESS: 0030H
My code is the following: For the C file it is:
#include <t89c51ac2.h> void _wait_ms(unsigned int length_delay); void init(void); int main(void) { init(); _wait_ms(300); return 0; } /*init() /****************************************************************************************/ /*Purpose: This routine initializes interrupts, and A/D */ /*Input: none */ /*Outputs: none */ /*Registers Modified: ADCON - A/D Control Register */ /* ADCF - A/D Configuration Register */ /****************************************************************************************/ void init(void) { /*A/D Configuration*/ ADCF |= 0x80; //Select CH7 as Analog In ADCON |= 0x47; //Enable CH7 for conversion //and Enable ADC return; }
And for the assembly file it is
; delay.SRC generated from: delay.c ; COMPILER INVOKED BY: ; C:\Keil\C51\BIN\C51.EXE delay.c BROWSE DEBUG OBJECTEXTEND ; Modified by Roque Obusan 02/09/2009 ; Reason - add delay NAME DELAY ?PR?_wait_ms?DELAY SEGMENT CODE PUBLIC _wait_ms ; #pragma SRC ; void wait_ms(unsigned int length_delay) RSEG ?PR?_wait_ms?DELAY _wait_ms: USING 0 ;---- Variable 'length_delay?040' assigned to Register 'R6/R7' ---- ;---- Variable 'i?041' assigned to Register 'R5' ---- ;check for 0 ms delay, exit if found MOV A, R7 JNZ ?MLOOP MOV A, R6 JNZ ?MLOOP JMP ?EXIT_WAIT_MS ?MLOOP: ;loop constant to cause the delay of 1 ms MOV R5, #0xff ;delay loop to cause the 1 ms delay ?SLOOP: NOP NOP NOP NOP NOP NOP NOP MOV A, R5 SUBB A, #0x01 MOV R5, A JNZ ?SLOOP ;checks if delay is complete ;MSB first w/ carry MOV A, R7 CLR C SUBB A, #0x01 MOV R7, A JNZ ?MLOOP ;LSB secondly w/ carry MOV A, R6 SUBB A, #0x00 MOV R6, A JNZ ?MLOOP ?EXIT_WAIT_MS: RET ; END OF _wait_ms END
check the numbers of underscores...
thank you
