LPC2103 I2C Problem
I have a LPC2103 board. I read the samples, I applied it in Keil and simulate with proteus but it isn't working.
The sample is that; (Application notes.)
www.standardics.nxp.com/.../an10369.pdf
My circuit;
img440.imageshack.us/my.php
But i2c is not working I can't send the data to expander.
[code]
#include <LPC2103.h>
void I2C_ISR(void) __irq;
void ISR_8(void);
void ISR_18(void);
void ISR_28(void);
int main(){
MEMMAP = 0x02;
VICIntSelect = 0x00;
VICIntEnable = 0x200;
VICVectCntl0 = 0x29;
VICVectAddr0 = (unsigned long) I2C_ISR;
PINSEL0 = 0x50;
IODIR=0xF00000F0;
//IOSET=0xF0;
//I2C ayarlari
I2C0CONCLR = 0x6C;
I2C0CONSET = 0x40;
I2C0SCLH = 0xC;
I2C0SCLL = 0xD;
I2C0CONSET = 0x60;
while(1);
void I2C_ISR() __irq
int temp=0;
IOSET = 0xF0000000;
temp=I2C0STAT;
switch(temp) { case 8: ISR_8(); break;
case 24: ISR_18(); break;
case 40: ISR_28(); break;
default : break;
} VICVectAddr=0xFF;
void ISR_8(){
// Port Indicator
IOCLR=0x10;
// Slave address + write
I2C0ADR=0x74;
// Clear SI and Start flag
I2C0CONCLR=0x28;
// Port Indicator
IOSET=0x10;
void ISR_18(){
// Port Indicator
IOCLR=0x20;
// Data to be transmitted
I2C0DAT=0x55;
// clear SI
I2C0CONCLR=0x8;
// Port Indicator
//IOSET=0x20;
void ISR_28(){
// Port Indicator
IOCLR=0x80;
//Transmit stop c
I2C0CONSET=0x10;
//clear SI
I2C0CONCLR=0x8;
//Port Indicator
//IOSET=0x80;
[/code]
