Using the Flash File System with microlib
I read through the documents that stated that the microlib doesn't support the Flash File System. I am curious if there's a work around for this. In the project, if I don't select the microlib checkbox, the code doesn't run correctly with RTX. I want to use the RTX OS but it seems like without the microlib, it doesn't jump to main when I started to debug. Any suggestions?
Thanks,
Tom
