How to pass argument to assembly file?
I want to assemble a certain portion of my *.a51 file based upon some argument that I pass from the command line or the GUI (Options->A51->SET).
When I pass the argument/symbol by writing something in the field (Option->A51->SET), e.g. COMPILE_FOR_SINGLE_PHASE, it still processes any #define under COMPILE_FOR_THREE_PHASE:
$IF COMPILE_FOR_SINGLE_PHASE #define SinglePhase
$ENDIF
$IF COMPILE_FOR_THREE_PHASE #define ThreePhase
$ENDIF
The problem is that it defines both of the macros "SinglePhase" and "ThreePhase", which creates havoc.
If I remove the #define from both of them and replace it with __ERROR__ "This line is parsed by assembler", the conditional directives are working fine.
I am using:
1. uVision3 v3.03
2. C51.exe v7.06
3. a51.exe v7.07
4. bl51.exe v5.03
I am NOT using MPL.
Any help would be appreciated.
Regards
Aman
