Finate State Machine
Hai All,
I am Implementing finate state machine and approach is as follows:
enum FSM_GATE_STATES
 GateOpen=0,
 GateClose
struct FSM_Gate
        enum FSM_GATE_STATES ActiveState;
struct FSM_Gate m_FSM_Gate;
void main()
  m_FSM_Gate.ActiveState=Gopen;
switch(m_FSM_Gate.ActiveState)
 Case GateOpen:
    if(gateOpen_Gateclose())
       m_FSM_Gate.ActiveState=GateClose;
  else
  //generate out put
 break;
Case GateClose:
//similar implementation
break;
bit gateOpen_Gateclose()
 if(inputTable[1]&&inputTable[2]....n)/*inputs from the field*/
   return 1;
 else
 return 0;
This my approach of FSM...
Since the FSM is as single program..I am having 19 states and 38 transition conditions...It is very hard to maintain it as configurable...
Is there any other efficient approach...
I need to place the transition conditions in EEPROM give me suggestions...
In this program transition condition is like function
that is
bit gateOpen_gateClose
{ if(inputTable[]....) { return 1; } else { return 0; }
I want to make transition as configurable data...
can this function changed in to boolean expresssions???? and stored in EEPROM...And I want to Implementing without pointers because of saftey critical machine...Thats my requirement.....Kindly give me suggestion....
