Dear Sir:
I am using lpc 2468 processor and uvision compiler.
I have following c++ structure
struct{ BYTE a; //8bits BYTE b; //8bits WORD c; //16bit }
in the begin, the corresponding memory is 00 00 00 00 after let's say, I assign a = 1, b = 2, I got 01 02 00 00 however, if I assign c some value, let's say, c = 0x0a0b,instead of have
01 02 0a 0b, which is what I want. I got 01 0b 0a 00.
if I change my struct to struct{ BYTE b; //8bits WORD c; //16bit } and do similar assign as above, i will get 0b 0a 00 not 01 0a 0b.
Can you please tell me what is wrong and how to solve the problem?
Thank you!
Z
Thank you all for your replies. It is a large program. Here is the part I believe it is related to this problem. Instead of getting
0xa1 0xa2 0xc8 0x0c 0xa3 0xa4
I actually get
0xa1 0x0c 0xc8 0x00 0xa3 0xa4
Thank you all.
Regards,
Zhan Liu
P.S. After preview, it looks very weird and some part bbarely readable. However, I checked the "tips for postiing messages and did not know how to fix it. So I jjust post it anyway to see if it is o.k. If not, I will try to repost.
typedef union { MP_FEEDBACK_HEADER m_Header; MP_UNIT_INFO_FEEDBACK m_UnitInfoFeedback; MP_UNIT_RESET_STATUS_FEEDBACK m_UnitResetStatusFeedback; MP_READ_IV_FEEDBACK m_ReadIvFeedback; MP_READ_AUX_FEEDBACK m_ReadAuxFeedback; MP_READ_PULSE_FEEDBACK m_ReadPulseFeedback; MP_READ_IR_FEEDBACK m_ReadIrFeedback; MP_READ_SMART_BATTERY_STATE_FEEDBACK m_ReadSmartBatteryStateFeedback; MP_READ_SMART_BATTERY_WORD_FEEDBACK m_ReadSmartBatteryWordFeedback; MP_READ_SMART_BATTERY_STRING_FEEDBACK m_ReadSmartBatteryStringFeedback; MP_READ_SMART_BATTERY_CLOCK_STRETCH_FEEDBACK m_ReadSmartBatteryClockStretchFeedback; MP_READ_ACI_FEEDBACK m_ReadAciFeedback; MP_READ_MCELL_ACI_FEEDBACK m_ReadMCellAciFeedback; MP_POWER_ON_FEEDBACK m_PowerOnFeedback; } MP_FEEDBACK; typedef struct { BYTE m_btUnitId; BYTE m_btCmd; // = MPC_UNIT_INFO WORD m_wFirmwareVersion; BYTE m_CheckSum[2]; } MP_UNIT_INFO_FEEDBACK; void Cmd::MPUnitInfoFeedback(MP_UNIT_INFO_FEEDBACK* pFeedBack) { //zl, debug only pFeedBack->m_btUnitId = 0xa1; pFeedBack->m_btCmd = 0xa2; pFeedBack->m_CheckSum[0] = 0xa3; pFeedBack->m_CheckSum[1] = 0xa4; /////////////////////////////////////// //zl // _swp(51212, &pFeedBack->m_wFirmwareVersion); pFeedBack->m_wFirmwareVersion)) = 51212;//zl,0xc80c } void Cmd::CmdParse(void) //a static case MPC_UNIT_INFO: #ifdef _DEBUG SendFeedBack(MPCS_ACK, m_CmdLen + 3); //feed back the data we get from PC #else MPUnitInfoFeedback(&m_pFeedBack->m_UnitInfoFeedback); SendFeedBack(MPCS_ACK,sizeof(MP_UNIT_INFO_FEEDBACK)); #endif break; } /* * File: main.c * Purpose: sample program * */ #include <stdio.h> #include "BasicDataType2468.h" //#include "mcf5272.h" //#include "Sys_Init.h" #include "SF_Hwf.h" #include "Switch.h" #include "Ctrl_Arbus.h" #include "Ctrl_IvAdc.h" #include "Ctrl_BoardCfg.h" #include "Ctrl_Timer1ms.h" #include "Enet_Socket.h" #include "Ctrl_BoardCfg.h" #include "Ctrl_IvChan.h" #include "Ctrl_Pulse.h" #include "Ctrl_Ir.h" #include "Ctrl_Aci.h" #include "Ctrl_Ramp.h" #include "Ctrl_Dio.h" #include "Ctrl_AuxChan.h" #include "Cmd.h" #include "Uart_Serial.h" #include "main.h" //zl #include "VARIABLES_G.h" #include "target.h" #include "timers.h" #include "emac.h" // Keil: Line added #define extern #include "tcpip.h" int main(void) { //zl #pragma arm section rwdata = "SRAM",zidata = "SRAM" DRAM 0X80000000 0x00010000 #pragma arm section //zl, end of off chip related codes Ctrl_BoardCfg::Init(); Ctrl_BoardCfg::DetectSys(); for(unsigned long uw32_i = 0;uw32_i < 6000000; uw32_i ++); // TargetResetInit(); for(unsigned long uw32_i = 0;uw32_i < 6000000; uw32_i ++); // µÈÂ'ýÆäËûÆ÷¼þ³õʼ»¯Ãê±à uw16_TimeStampNo = 0; uw32_TimeStamp = 0; Init_Device(); //2468 Cmd::Init(); for(;;) { if (!(SocketStatus & SOCK_ACTIVE)) TCPPassiveOpen(); // listen for incoming TCP-connection DoNetworkStuff(); //2468 Cmd::CmdParse(); //init device form 2468 void Init_Device(void) { TCPLowLevelInit(); *(unsigned char *)RemoteIP = 196; //EEP_RemoteIP[0]; // uncomment those lines to get the Ã"¶³Ì¼ÆËã»úIP *((unsigned char *)RemoteIP + 1) = 168; //EEP_RemoteIP[1]; // quote of the day from a real *((unsigned char *)RemoteIP + 2) = 1;//EEP_RemoteIP[2]; // internet server! (gateway must be *((unsigned char *)RemoteIP + 3) = 100; //EEP_RemoteIP[3] ; //208 203; // // set to your LAN-router) // *(unsigned char *)MyIP= 196; // EEP_RemoteIP[0];//192; // "MYIP1.MYIP2.MYIP3.MYIP4" ±¾»úIP *((unsigned char *)MyIP + 1)= 168; //EEP_RemoteIP[1];//168; *((unsigned char *)MyIP + 2)= 1; //EEP_RemoteIP[2];// 1; *((unsigned char *)MyIP + 3)= 1; //dsp_id; // *((unsigned char *)MyMAC + 5)= 1; //zl, //dsp_id; TCPRemotePort = 9030;//TCP_PORT_QOTD;Ã"¶³Ì¶Ë¿ÚºÅ UDPLocalPort = 2040;//2025;±¾µØ¶Ë¿ÚºÅ UDPRemotePort = 9040;//UDP_PORT_QOTD;Ã"¶³Ì¶Ë¿ÚºÅ TCPPassiveOpen(); DELAY_SYS(6000*60); //delay 60ms //zl DoNetworkStuff(); init_timer( 1,TIME_INTERVAL1ms); // init_timer( 3,(TIME_INTERVAL1us+1)*100-1); }
i askingh,
pleese be showing the smallller code who be showing the error but compliles.
you be using for us two much code who not show and comfusing me.
