Dear Sir:
I am using lpc 2468 processor and uvision compiler.
I have following c++ structure
struct{ BYTE a; //8bits BYTE b; //8bits WORD c; //16bit }
in the begin, the corresponding memory is 00 00 00 00 after let's say, I assign a = 1, b = 2, I got 01 02 00 00 however, if I assign c some value, let's say, c = 0x0a0b,instead of have
01 02 0a 0b, which is what I want. I got 01 0b 0a 00.
if I change my struct to struct{ BYTE b; //8bits WORD c; //16bit } and do similar assign as above, i will get 0b 0a 00 not 01 0a 0b.
Can you please tell me what is wrong and how to solve the problem?
Thank you!
Z
Please post the code where you actually do the assignment along with the actual variable definitions. A number of things can go wrong here. Don't forget the 'pre' and '/pre' tags.
Are the instructions really that difficult to see or understand:
www.danlhenry.com/.../keil_code.png
Don't manually re-type the code into the post - use only copy-and-paste;
Note that TABs don't work (well) - use spaces instead,
and don't forget to check it in the 'Preview'...
we is being scared he away me be thinks???
maybe he's cross-posting...
