I am student of electronics engg. I am using luminary kit LM3S6918 for the project purpose. While downloading the program on the kit using keil uv-3 and ULINK2 JTAG-USB adapter i am getting the error Target DLL has been cancelled. plz give me proper solution for the same.
try to reduce JTAG Clock I got the same problem when I set the JTAG Clock too high
Hello SSV SSV,
Please select ULINK Cortex Debugger under Options for Target - Utilities. Under Settings you must also spezify the correct Programming Algorithm.
Best Regards, Martin Guenther
I tried the same for many times i.e i selected JTAG CORTEX DEBUGGER in debug as well as in utilities. But i am still getting the same error. Again i tried to download the program using LM flash programmer.In configuration under interface i selected JTAG-FTDI interface but there i am getting error that "unable to connect to target". Are there any other settings required in LM flash programmer to dowmload the program??? I also tried to download the program through serial port.Kit responds to the basic program of accesing the door and gives reply on the hyper terminal.But i am unable to download the new program on it. Please kindly give the solutions for the same.
Try to unlock processor with LM Flash Programmer. This problem is widely discussed on Luminary's homepage, see the forum section.
Georg
