Dear All, How to download .bin file into my target board using ULINK. I am expecting a service like stand alone flash programmer. Is it possible with ULINK? if yes, then which executable file we have to run.
Thank you, Regards, Nani
You can flash an axf or hex file directly (but not bin files).
Convert your bin file to a hex file and use the following procedure described in the uVision manual: http://www.keil.com/support/man/docs/uv3/uv3_fl_hexdownload.htm
