Hi, i am facing a problem when i want to read the data,i enter the character twice the next time i get a unicode char on the screen................i dont know why.............when i do UART_WRITE() then UART_READ its fine ..........but problem is when i use UART_READ() alone...
Your problem description isn't really clear.
You say you have a problem when you only use UART_READ - which would imply when your uC only reads from the serial port.
But in that case - what screen are you talking about? If it is the PC screen, how did any data arrive there? If a display connected to your uC, then you will have to supply more information about that.
By the way: On the right-hand side of your keyboard, below the backspace key and above the shift key, you have a return or enter key. It works very well to use this key to produce new paragraphs, instead of playing with .............. to separate text segments. If you don't want a new paragraph, but just want to end a sentence, then you use one (1) stop/period/dot. If it happens to be a question, you replace that single dot with a single question mark. Then you have the single exclamation mark. Or - to push the envelope a bit and mark something really strong, you may use three (3) punctuation characters: ???, !!!, ??!, ...
