I am using Realview (evaluation) and have the following program for LPC2148:
#include <LPC214x.h> #define LED 0x01000000 main() { IO1DIR |= LED; //use P1.24 for(;;){ IO1CLR |= LED ; IO1SET |= LED; } }
the crystal is 12M and multiple factor is 5, no VPB setup (i also tried VPBDIV=1). It means the system should run with CPU clock=60Mhz The problem is the LED blinks only with 1 MHz. I tried simulation but the time shown there still indicate that the LED blinks with frequency around 30Mhz. This happen not only with the LED but with any code i put. It seems that my system runs with 2Mhz CPU clock. Does any one have the same problem, please help me. Thanks a lot.
we have same problem but we change mam numbers(startup.s) but nothing changed what are correct value pll and mam or exct.i must see about 30 mhz
