any 1 have the schematic diagram of microcontroller...for mon51
i wan to ask that...even the microcontroller have internal ram/rom, it also require external ram/rom ? it must hav: 1 external ram (store program) 1 eeprom (for mon51 program) 1 microcontroller 1 latch max232 and rs232 ...?
any ?~~~ pls = =
There are more than one hardware that can run MON51.
How about buying existing hardware?
If your goal is to build the hardware yourself, then I recommend that you spend your own time figuring out the requirements and how to connect - if you do not understand your schematic, then it will be hard to get it to work.
ya, i wan to build the hardware myself the mon51 require external eeprom and ram, eeprom for mon51 program, and ram(von neum) for code.
can i only using 1 ram? for mon51 program and program code??
can u help me~~ ? can i only using one ram for mon51 program and program code??
If you only have RAM how will you get the monitor program into the RAM chip so you can run it?
we cant save the monitor program in ram too ? same with the program code, both save in ram? can it work ?
How are you going to get it in to RAM? The CPU can not do it without running code. Or are you going to build some external device to put the program into the RAM. Or is the Program going to be in a chip with Flash program memory?
