Keil configuration in order to use a PSD833F2 with AT89S52
Hi, I have been trying to configure this but my code just keeps not working.
My program compiles in Keil and there are no errors, I create a .hex file.
I also use a code merger (PSDsoftExpress) in order to merge the PSD and MCU firmware and after I program the PSD. Everything seems to be right but when I run the program it does not work since the variables contain garbage. I supposed this is because the configuration is not correctly done. Therefore I am asking for help to solve this problem, this is very important.
Thank you in advanced.
