can any one give the correct syntax for HEX2BIN CONVERSION. I refered in the website it is not clear and it is not working . thanks in advance
In what way is it "not clear"?
How can anyone explain it more clearly, if they don't know what you need clarifying?!
Are you saying that the syntax given at http://www.keil.com/download/docs/7.asp is not correct?
Syntax: HEX2BIN [/option] hexfile [binfile] hexfile is the Intel HEX input file binfile is the binary file to create option may be any of the following /Ln Binary file length /Pn Pad data for binary file /On Address offset (to add to HEX records) /M Merge data into existing BIN file /Q Quiet mode (no statistics are displayed) /X Don't process ext. segment/linear address records /? This help text
If myfile.hex has gaps and I want to keep the gaps in erased state I'd fill them with FF.
Both HEX2BIN /f0xff myfile.hex and HEX2BIN /f255 myfile.hex fill the gaps with 00 and not FF as I expected.
found a better one at sourceforge.net/.../showfiles.php
But there is no "/f" option listed in the syntax for Hex2Bin - did you try "/P"...?
