I am not able to run the foll. example of rtx tiny
#include <rtx51tny.h>
int counter0; int counter1;
void main(void)
void job0(void) _task_ 0 { os_create_task(1);
while(1){ counter0++; //printf("%d",counter0); } } void job1(void) _task_ 1{ while(1){ counter1++; } } following is the error i get
Build target 'Target 1' linking... BL51 BANKED LINKER/LOCATER V5.03 - SN: Eval Version COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002 "STARTUP.obj", "rtos.obj" TO "rtos" Rtx51Tiny *** FATAL ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: C:\KEIL\C51\LIB\RTX51TNY.LIB Target not created
Is it actually included in the Eval version...?
I am using eval version of keil uvision 2
You didn't answer the question!
Have you confirmed that RTX Tiny is actually included in the Eval Version?
If it's not included then, obviously, you won't be able to use it - will you?!
Thanks I tried it on full version Its working fine
Thks again
sachin
