Please help me!
Hello everybody!
I have a problem by using Hmote2430 and Keil compiler for my sensor network project. When I use Keil compiler to compile my NesC code, I have some error as follow:
vu_anh_dung@anhdung /opt/tinyos-2.x/apps/Battery3
$ ./AUTOMAKE.sh
C:\cygwin\opt\tinyos-2.x\apps\Battery3\build\hmote2430>echo off
A51 MACRO ASSEMBLER V8.01 - SN: K1MMC-0LE18C
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2007
ASSEMBLY COMPLETE. 0 WARNING(S), 0 ERROR(S)
C51 COMPILER V8.12 - SN: K1MMC-0LE18C
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2008
*** WARNING C219 IN LINE 1527 OF APP.C: long constant truncated
*** ERROR C136 IN LINE 1596 OF APP.C: invalid dimension size: [0]
C51 COMPILATION COMPLETE. 1 WARNING(S), 1 ERROR(S)
LX51 LINKER/LOCATER V4.25 - SN: K1MMC-0LE18C
COPYRIGHT KEIL ELEKTRONIK GmbH 1995 - 2007
startup.obj, app.obj TO app CLASSES( XDATA(X:0xE000-X:0xFF00), IDATA(I:0-I:0xFF)) REGFILE(app.reg)ma
*** ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: APP.OBJ
Extended 8051/251 Object to Hex File Converter V1.36b
COPYRIGHT KEIL ELEKTRONIK GmbH 2000 - 2006
*** ERROR: CAN'T OPEN FILE 'app'
***** app.hex is created.. upload IMAGE to CC2430 !! *****
**** You can use SmartRF04 Flash Programmer (chipcon) ****
ls: app.hex: No such file or directory
- To implement on Hmote2430 device, I used app.hex file to implement on it. but Keil compiler can not generate hex file by this error.
- If I copy the APP file generate from another program, Keil compiler can generate hex file but the result same to that another program.
- I need some help, please!
  • Was "Please help me!" a descriptive summary?
    Have you taken a closer look at:
    We can't do it for you. We do not know the contents of line 1527 and line 1596 of your APP.C file.
    Always take care of problems in the order they arrive, instead of trying to cheat the last step by copying an other hex file or similar.
    When the C code is correct and compileable, then there will be an APP.OBJ file, and then the linker will have the required files to try to create a HEX file.
    Another thing: The AUTOMAKE.sh file seems a bit stupid, since it prints "app.hex is created" when no such file is actually created.
  • Thank you so much for your answer.
    If possible, please check it for me, because I can not post my program to website, and so sorry for my English limited.
    line 1526: TransformCounterC__0__OVERFLOW_MASK = /*CounterMilli32C.Transform*/TransformCounterC__0__NUM_UPPER_BITS ? ((/*CounterMilli32C.Transform*/TransformCounterC__0__upper_count_type )2 << (/*CounterMilli32C.Transform*/TransformCounterC__0__NUM_UPPER_BITS - 1)) - 1 : 0
    line 1527: };
    line 1596:typedef int /*HilTimerMilliC.AlarmToTimerC*/AlarmToTimerC__0____nesc_sillytask_fired[/*HilTimerMilliC.AlarmToTimerC*/AlarmToTimerC__0__fired];
  • Guess what?
    People can't help you unless they have access to _all_ relevant symbols required to decode a source line.
    The symbol AlarmToTimerC__0__fired is probably zero, which it most probably should not be. Time for you to check why.
    The warning line (1526) uses a large number of symbols that I can not know the value/type of.
    But the above problems are generic C problems. You do know C?
    By the way: Why not format the code as code when posting? This is clearly described in the text just above the message box when you write a post.
  • - Sorry for my limited because I don't know C language.
    My NesC code below:
    configuration TestSensorC {
    implementation {
        components MainC, TestSensorP;
        MainC.SoftwareInit -> TestSensorP.Init;
        MainC.Boot <- TestSensorP;
        components LedsC;
        TestSensorP.Leds -> LedsC;
        components new TimerMilliC() as TimerC;
        TestSensorP.Timer -> TimerC;
        components StdOutC;
        TestSensorP.StdOut -> StdOutC;
        components BattC;
        TestSensorP.BattControl -> BattC.StdControl;
        TestSensorP.Batt -> BattC.SimpleADC;
    module TestSensorP {
        provides interface Init;
        uses interface Boot;
        uses interface Timer<TMilli>;
        uses interface Leds;
        uses interface StdOut;
        uses interface StdControl as BattControl;
        uses interface SimpleADC as Batt;
    implementation { float value;
    command error_t Init.init() { return SUCCESS; }
    event void Boot.booted() { call Leds.led1On(); call Leds.led0On();
    call StdOut.print("*************************\n\r"); call StdOut.print("* Program initialized *\n\r"); call StdOut.print("* Exercise 7 : Voltage *\n\r"); call StdOut.print("*************************\n\r");
    call BattControl.start(); call Timer.startPeriodic(300); } event error_t Batt.dataReady(uint16_t data, uint8_t status) { call StdOut.printBase10uint16(data); call StdOut.print(" : "); value = data*0.0183195; call StdOut.printBase10uint16(value); call StdOut.print("mV"); call StdOut.print("\n\r"); } event void Timer.fired() { call Leds.led1Toggle(); call Batt.getData(); } async event void StdOut.get(uint8_t data) { return; } }
    ***My process below***
    Compile NesC code:
    $ make hmote2430
    mkdir -p build/hmote2430
    ncc -S -Os -I/opt/tinyos-2.x/tos/platform/hmote2430 -D__hmote2430__=1 -Wall -Wshadow -DDEF_TOS_AM_GROUP=0x7d -Wnesc-all
    -conly -target=hmote2430 -fnesc-cfile=build/hmote2430/app.c -board=hy2430  TestSensorC.nc 2>&1 | \
            grep -v "attribute directive ignored"
    /opt/tinyos-2.x/tos/chips/cc2430/ioCC2430.h:259: warning: non-atomic accesses to shared variable 'SLEEP':
    /opt/tinyos-2.x/tos/chips/cc2430/McuSleepC.nc:61: warning:   non-atomic write
    /opt/tinyos-2.x/tos/chips/cc2430/McuSleepC.nc:61: warning:   non-atomic read
        compiled TestSensorC to build/hmote2430/app.c
    cp /opt/tinyos-2.x/support/make/mcs51/startup.a51 build/hmote2430
    cp /opt/tinyos-2.x/support/make/mcs51/startup.bat build/hmote2430
    cp /opt/tinyos-2.x/support/make/mcs51/MAKEHEX.sh        build/hmote2430
        compiling TestSensorC to a hmote2430 binary
    mv build/hmote2430/app.c build/hmote2430/app.preMangle.c
    perl -w /opt/tinyos-2.x/support/make/mcs51/mangleAppC.pl --KEIL --file=build/hmote2430/app.preMangle.c > build/hmote2430
    /app.c
    cp /opt/tinyos-2.x/support/make/mcs51/CC2430-F128.bat build/hmote2430
    cp /opt/tinyos-2.x/support/make/mcs51/AUTOMAKE.sh .
        compiled TestSensorC to a hmote2430 binary
    **** Build Completed!!! ****
    Generate Hex file:
    $ ./AUTOMAKE.sh
    *** WARNING C219 IN LINE 1519 OF APP.C: long constant truncated
    *** ERROR C136 IN LINE 1588 OF APP.C: invalid dimension size: [0]
        FILE: APP.OBJ
  • Because my app.c file has more than 4000 line, I upload on internet, please check it for me.
    this is a app.c file.
    www.box.net/.../ylq4gbjzdt
  • You did notice that the C51 compiler did complain about the contents of APP.C?
    That means that the _C_ code must be examined. The nesC code will not contain the relevant constants - they are generated by the nesC to C converter.
    Your problems _may_ be because you have a problem with the nesC code.
    Your problems _may_ be because the nesC to C converter does not produce code that is compatible with the C51 compiler.
  • Thanks, I think my problem was not in NesC code, because when I compiled NesC code, there is no error and have some warning, and if I have something wrong in NesC, the compiler will give me the error message. But when I generated to Hex file by app.c file, I have had some errors what I don't know. So how to solve this problem, could you give me some advise? I really feel worried now.
