Hello, I'v installed an evalutation version of uVision. (details below) Now when I open a project and open the "debug" tab in the "options for target" dialog, I can select the ULink as debugger. When I open the settings screen for the debugger, I see that the Ulink and my target CPU are detected correctly.
When I want to setup the flash algorithm in the "utilities" dialog, I select "Use target driver for flash programming".
But then I can't select the ULink in the dropdownlist. In fact, the list is completely empty.
Can someone tell me how this is possible, since everything seems to be installed correctly.
Kind regards, Sander Wiggers
Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 3.22a Toolchain Path: BIN31\ C Compiler: Armcc.Exe V3.1.0.934 [Evaluation] Assembler: Armasm.Exe V3.1.0.934 [Evaluation] Linker/Locator: ArmLink.Exe V3.1.0.934 [Evaluation] Librarian: ArmAr.Exe V3.1.0.934 [Evaluation] Hex Converter: FromElf.Exe V3.1.0.934 [Evaluation] CPU DLL: SARM.DLL V3.22a Dialog DLL: DARMP.DLL V1.40 Target DLL: BIN\UL2ARM.DLL V1.40 Dialog DLL: TARMP.DLL V1.40
why not use the latest, 3.70 rather than 3.22?
Does V3.70 fix this problem?!
V3.22 always worked fine. Untill today when I installed it on another pc.
