I need to use that small liqued crystal LCD displaty.
Does anyone know what type of controller is used inside ?
Or any programming hints ?
Sorry, but you forgot to post the photo so we can see what display you are pointing at.
I want 2 but I cant.
You want two Liquid Cystal LCD Displays? Are you going to display stereographic images?
the manufacturer does and thus the manufacturers datasheet is your source for which signals to use to drive it.
erik is right. you will have to find out which display you are going to use and which controller, if ever, it uses.
