I would like to ask if anyone know where to learn C programming on uVision and dScope. I am new to this language and new to electronics, first timer. So I would like to get more information regrading this so that I can proceed with my work....
Start by learning C, independent of uVision:
publications.gbdirect.co.uk/.../
Then, spend time understanding your microcontroller:
Chapter 1 www.semiconductors.philips.com/.../80C51_FAM_ARCH_1.pdf
chapter 2 www.semiconductors.philips.com/.../80C51_FAM_PROG_GUIDE_1.pdf
chapter 3 www.semiconductors.philips.com/.../80C51_FAM_HARDWARE_1.pdf
dScope was already obsolete years ago!
I agree with Tamir: with no prior 'C' experience, it is probably easiest to learn it on a PC or similar first - then apply that learning to embedded systems and uVision, etc.
Check the book list: http://www.keil.com/books/
See also: http://www.8052.com/links http://www.8052.com/tutorial http://www.8052.com/sbc/
Something to beware of: www.8052.com/.../159118
with no prior 'C' experience, it is probably easiest to learn it on a PC or similar first - then apply that learning to embedded systems and uVision, etc. ... that does not require fluency in C to be understood.
o ok thx guys, other than that, where do i find tutorial on teaching me how to control the LED lights using C programming?
James; You really need to pay attention to the suggestions that Andy Neil has placed before you. Also, look at the Keil examples for the 'Blinky' example. Bradford
o ok i will read up those links thx!
