Dear all,
i am gettting a serious problem in Flash Download-ARM7TDMI in LPC2214.So i gone to the some of threads , i got the solution as Use Target Driver for Flash Programming"->Settings to LPC2000 IAP2 512Kb Flash,but still iam not able download the code into chip.again i traied but i couldn't resolve the problem.so can any body explain what is the reason and please kindly give me the sugessitions to resolve this problem.please help me in this matter, please consider as urgent.
thanks
First you need to select the correct Flash algorithm for LPC2214 which is LPC2000 IAP 256kB Flash.
If it still doesn't work then you should provide more info about the problem like what exactly doesn't work, what error messages you get ...
Make sure your max jtag clock is set correctly. Options->Debug, ULINK ARM Debugger settings. 200kH seems to work fine, the default on a new project is 1Mhz.
This tripped me up for a day too!
Nate
Yes, you need to select the correct Flash algorithm and reduce the max Jtag clock in my experience, so if you carry out both suggestions above you should get it working.
