Hello everybody.
I am new to USB programming, and I am having some trouble with it. I am working with a MCBSTR750 board, and have to program it to communicate with the PC via USB bulk transfers.
In order to do that, I've started editing the USBHID example project. I have changed the descriptors (changed the HID for a custom class, added 2 bulk endpoints, etc), and a little bit of the main code, but it doesn't seem to work at all.
My question is: do I have to change anything of the usbcore.c file? I don't know how much functionality that file provides, but I guess it should be enough to do just transfers over a bulk pipe.
Thank you very much, I hope somebody can help me.
Best regards,
Inigo
don't touch usbcore.c post your descriptors here so people can analyze what you did. use the proper tags...
Hello, and thank you for your reply. The descriptors are as follows (the string descriptor is unchanged so I won't post it)
/* USB Standard Device Descriptor */ const BYTE USB_DeviceDescriptor[] = { USB_DEVICE_DESC_SIZE, /* bLength */ USB_DEVICE_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(0x0200), /* 2.00 */ /* bcdUSB */ 0x00, /* bDeviceClass */ 0x00, /* DeviceSubClass */ 0x00, /* DeviceProtocol */ USB_MAX_PACKET0, /* bMaxPacketSize0 */ WBVAL(0x3333), /* idVendor */ WBVAL(0x4444), /* idProduct */ WBVAL(0x0100), /* 1.00 */ /* bcdDevice */ 0x04, /* iManufacturer */ 0x20, /* iProduct */ 0x46, /* iSerialNumber */ 0x01 /* bNumConfigurations */ };
/* USB Configuration Descriptor */ /* All Descriptors (Configuration, Interface, Endpoint, Class, Vendor */ const BYTE USB_ConfigDescriptor[] = { /* Configuration 1 */ USB_CONFIGUARTION_DESC_SIZE, /* bLength */ USB_CONFIGURATION_DESCRIPTOR_TYPE, /* DescriptorType */ WBVAL( /* wTotalLength */ USB_CONFIGUARTION_DESC_SIZE + USB_INTERFACE_DESC_SIZE + 2*USB_ENDPOINT_DESC_SIZE ), 0x01, /* bNumInterfaces */ 0x01, /* bConfigurationValue */ 0x00, /* iConfiguration */ USB_CONFIG_BUS_POWERED, /* bmAttributes */ USB_CONFIG_POWER_MA(100), /* bMaxPower */ /* Interface 0, Alternate Setting 0 */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x00, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ 0x02, /* bNumEndpoints */ 0xFF, /* bInterfaceClass */ 0x00, /* bInterfaceSubClass */ 0x00, /* bInterfaceProtocol */ 0x60, /* iInterface */ /* Endpoint, Bulk In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_BULK, /* bmAttributes */ WBVAL(0x0010), /* wMaxPacketSize */ 0x00, /* bInterval */ /* Endpoint, Bulk Out */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_BULK, /* bmAttributes */ WBVAL(0x0010), /* wMaxPacketSize */ 0x00, /* bInterval */ /* Terminator */ 0 /* bLength */ };
Tamir used three sentences. The third one was "use the proper tags..."
