there was the same thread and answered as: looks like Flash programming fails. Did you select the correct XTAL freqeuncy (in the Project - Options - Target dialog).
but i use the correct value (8 mhz) what should i do??
original message:
I am using Keil uVision 3 and the Keil Ulink2 to flash via JTAG. I get this error message when I try to flash via uVision.
Build target 'Melexis test' assembling Startup.s... compiling sensor.c... linking... Program Size: Code=2484 RO-data=32 RW-data=28 ZI-data=1204 "test.axf" - 0 Error(s), 0 Warning(s). Load "C:\\Keil\\ARM\\Boards\\Keil\\MCB2100\\SensorCAN\\test.AXF" Erase Done. Programming Done. Contents missmatch at: 00000138H (Flash=5CH Required=BCH) ! Contents missmatch at: 00000139H (Flash=08H Required=07H) ! Contents missmatch at: 00000150H (Flash=08H Required=40H) ! Contents missmatch at: 00000151H (Flash=00H Required=11H) ! Contents missmatch at: 00000152H (Flash=90H Required=C1H) ! Contents missmatch at: 00000153H (Flash=E5H Required=E1H) ! Contents missmatch at: 00000154H (Flash=01H Required=08H) ! Contents missmatch at: 00000155H (Flash=08H Required=00H) ! Contents missmatch at: 00000156H (Flash=80H Required=81H) ! Contents missmatch at: 00000157H (Flash=E3H Required=E5H) ! Contents missmatch at: 00000158H (Flash=01H Required=04H) ! Contents missmatch at: 0000015AH (Flash=80H Required=81H) ! Contents missmatch at: 0000015BH (Flash=E3H Required=E5H) ! Contents missmatch at: 0000015CH (Flash=01H Required=40H) ! Contents missmatch at: 0000015DH (Flash=19H Required=01H) ! Contents missmatch at: 0000015EH (Flash=41H Required=81H) ! Contents missmatch at: 0000015FH (Flash=E2H Required=E1H) ! Contents missmatch at: 00000170H (Flash=04H Required=FFH) ! Contents missmatch at: 00000171H (Flash=00H Required=08H) ! Contents missmatch at: 00000172H (Flash=90H Required=A0H) ! Contents missmatch at: 00000173H (Flash=E5H Required=E3H) ! Contents missmatch at: 00000174H (Flash=AAH Required=C0H) ! Contents missmatch at: 00000175H (Flash=0FH Required=14H) ! Contents missmatch at: 00000176H (Flash=80H Required=C1H) ! Contents missmatch at: 00000177H (Flash=E3H Required=E1H) ! Contents missmatch at: 00000178H (Flash=01H Required=18H) ! Contents missmatch at: 00000179H (Flash=19H Required=00H) ! Contents missmatch at: 0000017BH (Flash=E2H Required=E5H) ! Contents missmatch at: 0000017CH (Flash=04H Required=41H) ! Contents missmatch at: 0000017DH (Flash=00H Required=08H) ! Contents missmatch at: 0000017EH (Flash=81H Required=A0H) ! Contents missmatch at: 0000017FH (Flash=E5H Required=E3H) ! [...the same missmatches] Too many errors to display !
I did never had this error before so... Does anyone did get this error before? What could be wrong?
