I've a problem using the twi-interface from the AT91RM9200 controller. At the moment, I'm not able to transmit any kind of signals (startbyte and so on)... both pins (clock and data) stay always high.
/* crystal frequency */ #define AT91_CRYSTAL 18420000 /* pll param -> processor-frequency */ #define AT91_MASTER_CLK ((AT91_CRYSTAL / 4) * 38 #define MCK (AT91_MASTER_CLK / 3) /* twi clock 100kHz */ #define AT91C_TWI_CLOCK 100000 #define I2C_ADDR 0x48
void AT91F_SetTwiClock(void) { unsigned int sclock; /* Here, CKDIV = 1 and CHDIV=CLDIV ==> CLDIV = CHDIV = 1/4*((Fmclk/FTWI) -6)*/ sclock = (10*MCK /AT91C_TWI_CLOCK); Â' if (sclock % 10 >= 5) sclock = (sclock /10) - 5; else sclock = (sclock /10)- 6; sclock = (sclock + (4 - sclock %4)) >> 2; // div 4 AT91C_BASE_TWI->TWI_CWGR = ( 1<<16 ) | (sclock << 8) | sclock; }
AT91F_TWI_CfgPIO(); AT91F_TWI_CfgPMC(); //disable all interrupts, reset twi, set master mode AT91F_TWI_Configure(AT91C_BASE_TWI); AT91F_SetTwiClock(); //read operation *AT91C_TWI_CR = AT91C_TWI_MSEN | AT91C_TWI_SVDIS; //internal device addr *AT91C_TWI_IADR = 0x01; *AT91C_TWI_MMR = ((I2C_ADDR<<16) //slave addr | AT91C_TWI_MREAD | AT91C_TWI_IADRSZ_1_BYTE); *AT91C_TWI_CR = AT91C_TWI_START | AT91C_TWI_STOP;
I can't find the error causing this problem. Maybe someone of you could give me some useful hints.
best regards Stefan
