I want using LPC2368's Ethernet Function with The Library RTLTCP.
I just changed the PHY chip from DP83848c to DM9161A and File LPC23_EMAC.c to suit DM9161A.
But None of the ethernet examples programs in MCB2300 could work.
Where is the Problem?
Thanks!
You are probably the only one who can answer that, since we don't know how you modified the code to support the new PHY.
