Writing ISR in arm9
Hello
what is the structure for writing specific ISR for different on chip peripherals?
  • Enter ISR
    Do job (as little and fast as possible)
    Make sure interrupt is acknowledged
    Leave ISR
    You really have to ask a more specific question.
  • when using any peripheral. e.g. UART then when after transmitting data when UnTHR (Transmitting buffer) gets empty. At that time the interrupt is generated and it should directly jump to ISR location. I don't know what is the structure of format for writing ISR in keil for any peripherals. It can be IRQ OR FIQ.
    the format is like
    void uart0_int (void) __irq;
    but it doest work. Thats my question.
  • There was a reason why I said that you must ask explicit questions, and not post a wild-card any-chip/any-peripherial/any-problem question.
    Have you looked at the example code that gets installed together with the compiler?
    Some chip manufacturesr also has sample code for their processor together with the Keil compiler.
  • yes i have looked at the sample codes. It doesn't have any code using this kind of interrupt structure.
    Morever the device LPC3180 is new from NXP and there are not much documents or support available for this device even from NXP. and peripheral simulation is also not given in keil for this particular device.
  • You normally declare an interrupt handler identically for different processors supported by the compiler, and then let the compiler handle any differences in the generated code and in the startup file.
    Exactly what do you mean by "using this kind of interrupt structure"?
    The compiler manual - and existing sample programs - should tell you how to declare an interrupt handler.
    The chip user manual will tell you what flags you need to access to acknowledge the interrupt controller and the specific interrupt source. And they will tell you:
    - what registers to read to pick up any received characters
    - what flags to look at to see if there are any errors
    - what flags to look at to see if there are room for more data to transmit
    Finding a 100% copy-paste function to use may be nice, but is not a requirement. The datasheets/user manuals are written with the intention that a developer should be able to design interrupt handlers for a device without any extra information. Source-code packs (quite commonly released by NXP) is icing on the cake, since they can shorten the time to get running. But in the end you are often better off with the documentation. Some of the NXP code is dumbed down quite a lot. Possibly to help people who don't know C.
  • Yes i mean by interrupt handler. as you mentioned in the reply.
    What should be the exact syntex?
    I am not getting it right for UART interrupt handler.
    I have checked all the register values and made sure that the interrupt gets enabled when transmit buffer finishes transmitting data. but the interrupt handler doesn't work.
  • Wouldn't a reasonable next step be to post the problematic code here?
    By the way: The example programs would show you the syntax of an interrupt handler. It most probably isn't the syntax that you have problems with, but what registers to write what values into, and when.
  • Hello This is my code.
    the interrupt handler for UART is not working.
    #include "LPC318x.h"
    void uart3_int (void) __irq
    { PIO_OUTP_SET = 0x7EFFFFFFF;
    PIO_OUTP_CLR = 0x7EFFFFFFF;
    int main (void)
    { unsigned char i;
    interrupt_init();
    SYSCLK_CTRL = 0x00000140;
    HCLKPLL_CTRL = 0x00014024;
    UARTCLK_CTRL = 0x0F;
    //U3RBR = 0x00;
    U3IER = 0x07;
    U3LCR = 0x03;
    U3FCR = 0x00;
    U3CLK = 0x0000020E;
    UART_CLKMODE = 0x00000550;
    U3THR = 0x00;
    /*U3DLM = 26;
    U3DLL = 27;
    U3LCR = 0x03;*/
    while(1)
    { PIO_OUTP_SET = 0x7EFFFFFF;
    PIO_OUTP_CLR = 0x7EFFFFFF;
    U3THR = 0x55;
    for(i=0;i<20;i++);
  • That is not an UART interrupt handler. It does not ask the UART for any pending events. It does not feed more characters to send. It does not pick up any received characters. It does not clear any overrun errors. It does not acknowledge that the interrupt has beeen handled.
    You really must be able to find sample code for an interrupt handler for your processor.
  • When i feed U3THR the CPU transmits the data over transmit. After transmitting the interrupt flag settled to one. When this is settled to one i want to blink LEDs.
    Thats the requirement for which i have written this code.
  • Your sample code for that incredible machine of yours will show you how. Jack Sprat wrote not long ago: "I have also noticed that you are not averse to using language that would be considered blasphemy by at least one of the major global religions". So you see Jack, I CAN glorify a processor core without the sin of blasphemy after all :-)
    but I admit having to bite my tongue!
