Dual ULINK2 causes problems
Dear all,
I made an update of the MDKK-ARM to 3.22a. This also updated the firmware of my two ULINK2's. After this update I am unabl to run two uVisions with each a ULINK2 and seperate target.
I used to be able to run two programs and debug the two targets, which are connected vai UART, with the two ULINK2's.
One of the programs jums to the 0xFFFFxxxx region after a breakpoint is reached. Location of breakpoint des not matter. It always happens.
I suspect the firmware update caused the problem. Do more of you hav ethis problem?
Is there a way to downgrade the firmware?
Best regards,
Dennis
