Hello !!!
I try to make an public address amplifier simulater for test befour blowing.
I must simulate the output of the amplifier who is generally fed to a transformer that has a secondary winding arranged to produce 1000 volts at full output on a wave.
Can be used an usual amplifier and an external step-up transformer or resister ? How can be calculated this transformer (number of turns etc. ) .Can be used ferrite core or must be magnetic? how can i simulate in the code for it? anyoNE Ggot code for it?
Or maybe somebody do have an schametic of an ransformerless pubic address amplifier.
Which is the best choice ??
Thank you !!!
You can of course use the Keil compiler and an ARM development board and write the relevant software to perform a SPICE simulation.
But really - ahre you 100% sure that you are on the correct forum?
