Calculation of stack sizes...
Hallo
I wonder if there are any good methodes of calculating the stack size for ex user or IRQ stack size? Is there any "best practice"?
Or is it just add up the size of data structures and/ot ISR's??
/Thomas
  • I still have some questions; this is really difficult to understand, for me.
    My platform is NXP LPC2378, which is an ARM7TDMI-S CPU (ARMv4T), with a 128-bit wide memory interface and an accelerator architecture.
    LDRD and STRD instructions are only available in ARM Architecture 5TE and later. So, I guess this means LDRD and STRD instructions are useless to me?
    => NB: Some ARM cores feature 64bit memory interfaces. These benefit from 8-byte aligned 64bit data access for performance reasons, despite the
    fact that most actually allow unaligned doubleword access :-) <=
    So, does this mean, 8-byte aligned memory access still benefits performance in a LPC2378?
    infocenter.arm.com/.../IHI0042C_aapcs.pdf
    5.2.1.1
    Universal stack constraints
    SP mod 4 = 0. The stack must at all times be aligned to a word boundary.
    5.2.1.2
    Stack constraints at a public interface
    SP mod 8 = 0. The stack must be double-word aligned.
    Does this mean, "the stack must be double-word aligned" is not mandatory in ARM ABI?
    Does REQUIRE8 mean that an obj-file certainly uses LDRD and STRD instructions? or it does not?
    Even the KEIL's library does not align and grow the stack in 8-byte steps, so I guess that, To be ABI compliant is not very important?
  • Now I know that, for assembly code, the stack alignment has to be done by programmer.
    But how about C code? I guess it is done by KEIL compiler?
  • > I still have some questions; this is really difficult to understand,
    That is proprietary external hardware to prefetch data from flash. Not
    what I was talking about. See below.
    > useless to me?
    Useless is probably the wrong word... If you use them on ARM7TDMI
    you'll likely get an UNDEF exeception.
    > the fact that most actually allow unaligned doubleword access :-) <=
    At least not in the sense that I was referring to. My memory interface
    sits between core and the rest of the world as the core sees it. This
    is certainly not wider than 32 bits on ARM7TDMI.
    > 5.2.1.1
    > 5.2.1.2
    Mandatory only at "externally visible boundaries", i.e. your public
    API or your own references to third party code (libraries).
    Example: Code calling your code might expect 8-byte aligned stack. If
    you violate that, things won't work. Since you can't know what someone
    else might expect, you have no choice but comply.
    Silly example: Your function calls third party code. A strange way of
    saying NOP (most ARM architectures don't have an actual NOP
    instruction) is by saying
    BIC sp, sp, #7
    somewhere in the subroutine. This shouldn't have any visible effect
    provided that the stack was properly aligned when you where calling
    the subroutine. Violating the stack alignment contract would break
    your program.
    Exceptions: Internal functions, that are not supposed to be used by
    anyone else and are not calling any functions themselves but your own
    (assuming you know what you are doing), may leave the stackpointer
    unaligned.
    ISRs must generally not rely on an aligned stack and may have to
    ensure an aligned stackpointer if they are calling other functions.
    First of all REQUIRE8 is just a claim.
    This is not true. ABI compliance is utterly important.
    Regards
    Marcus
    http://www.doulos.com/arm/
  • Hi Marcus,
    Many thanks for your explaination.
  • when i clean project then rebuild all then every thing were ok
