I am looking at the latest version of Keil RL-ARM V3.50. In the HTTP_UPLOAD example, keil provides a way to download the files that have already been uploaded to the SD Card when we click the directory listing. It ignores the folders on the card and lists them as files. What I am looking for, is a way to open these folders and access the files in them.
Does any one have a clue???
Thanks, Sivaram.
Hi Sivaram,
Have a look at the .attrib member in the FINFO structure, can recall off top of my head the patterns, but these bits represent the show folder, file, read-only etc.
regards Darren
Thank you for your reply...But I couldnot find the FINFO structure definition...
Hi
It's in RTL.h
Regards Darren
Darren,
The file RTL.h contains just the definition for the FINFO structure.Where do we modify anything regarding its configuration? How do you think that we can make the debugger list folders and files differently??
The .attrib member the bits here reflect the what the file folder attributes are..
I believe from memory
bit 1 = read only file bit 2 = hidden file bit 5 = folder bit 6 = archive file
(I could be wrong on some of the bit numbers)
best regards Darren
I discovered a simple way to do this today. I was trying to open a file in one of the folders on the SD Card.All I need to do is to add some code in http_fopen in HTTP_uif.c in order for the fopen for the web server to get the files from the respective folders.
